Jacks Web Site
Date:  3-31-2012
Number of Hours:  4.00
Manual Reference:  ?
Brief Description:  Preparing pin cover molds
Prior to cutting the holes in the cowl, I made molds to capture the contour of the cowl . To do this, I simply applied a layer of packing tape to the cowl where I needed to capture the contour. I than applied about 6 layers of 7 oz fiberglass to cover a sufficiently large area. I then pulled the mold off the cowl and cleaned up the edges. After the holes were cut, I used a marker to show where the covers needed to be. I then applied 6 layers of glass to the inside of the molde to make the cover. Prior to applying the glass, I secured a couple of countersunk washers where the screws would go through. This molded the wahers into the cover so that they would not be visible after painting.
Cover molds marked
Cover molds marked
Top side of mold
Top side of mold
Left mold in position
