Brief Description: Fitted oil filler door to the upper cowl
I made a drawing for the holes that I needed to cut into the door for the latches. I cut these holes and adjusted them for proper fit. I then cut the opening in the cowl to accomodate the door. I trimmed the door to size to fit into the hole. I then aped the door to the cowl and fierglassed a support ledge.
