Brief Description: Rivetted right wing tip hinge to wing tip
Further prepared the hinges for attachment to the wing tips. Drilled holes between the rivet holes and countersunk them to add as further grip for the epoxy used to attach the hinges. Countersunk the holes in the wing tips to accept flush rivets. Applied the hinges to the wing tip using glass resin and rivets. Used spring clamps to hold the hings in place whle the resin cured.
