Brief Description: Mounted wing tip antenna and lights
Mounted the nav antennas and nav/strobe lights in both wing tips. Nav antenna is mounted as far forward as possible and rivetted into the hinge. Light assembly is mounted in the corner slot provided for it. Wires for the antenna and lights are dressed along the leading edge of the antenna as prescribed by the mounting instructions. All wires were laced. Connectors were attached to wire ends so that they can be disconnected from the wing.
