Brief Description: Installed OAT, rivetted lower right wing skin
Finished up the servo installation by safety wiring the mounting hardware. Installed the Outside Air Temperature sensor in the bottom of the wing. Finally, rivetted the bottom skin onto the wing. I was able to complete the rivetting alone using a standard rivet gun and bucking bars. worked from the inside aft corder forward, finishing one rib at a time.
