Routed and terminated wiring for the Lightspeed ignition modules. Replace the provided connectors wth ones that used crimp-on pins. Routed the power wires up to the front panel. Installed the manifold pressure sensor for the Skyview engine monitor as well. Still searching for T's that can be used for the various tubing sizes needed to plumb these to the engine.
