Fabricated a box for the ignition backup battery out of .040 aluminum. The box has no bottom. It is attached to the firewall on the inside of cabin opposite the primary battery. The box is rivetted together and mounted on the firewall with the same bolts that mount the primary battery. The secondary battery is a 7 Amp-hr battery.
