Brief Description: Fitted Garmin stack to second bulkhead
Spent the day fitting the rear part of the Garmin stack frame to second bulkhead. This included cleaning up the hole cut for the instruments and fabricating angles to attach the sides to. Drilled and countersunk rivet holes. Clecoed the top skin onto the framework to assure that the fitting was accurate.
