Spent the day mounting the secod Skyview display. Cut the hole in the same way as i did for the larger unit. Cut holes for the mounting screws and the nut plates needed to attach them. Finally, I positioned the panel in the cockpit to cut clearances in the bulkhead behind the panel for the Garmin stack.
