Brief Description: Preparing snorkel transition form and first layup
The next step was to cut down the foam enough to add about 1/16" of bondo to form a smooth transition form. I sanded the bondo to be approximately even with the internal edges of the snorkel halves. I then added the first layup of fiberglass to the form. I added about 4 layers of glass. The first three were fit inside the gap in order to fill it. The last layup extended 1/4" on either side of the form.
