As the aileron does not move in a symetrical fassion, using the dremil tool, hte hole was cut to suite the movement. A hole was also frilled in the aileron mounting bracket - so the flap hinge rod could be installedremoved. The end aileron mounting bracket was riveted to the last rib.
