Brief Description: Installed elevator control system
CLAMPED THE ELEVATORS IN THE NEUTRAL POSITION.THEN,INSTALLED THE 3 PUSHRODS: 841,840 AND 839. INSTALLED THE F-635 BELLCRANK. INSTALLED THE2 CONTROL STICKS-WD411,FRONTANDWD-812 AFTSTICK. INSTALLED THE 893 PUSHROD ASSEMBLY. INSTALLED THE COMPLETED F-837CONTROL MOUNT. NEEDED TO ORDER 2 EACH AN4-25 BOLTS,NUTS AND WASHERS. ALSO RECEIVED FREE 5702-75-060 WASHERS THAT ARE USED NEXT TO BEARINGS FOR CONTAINMENT. SPENT ONE HOUR PUTING AWAY PARTS THAT HAVE BEEN LAYING ON THE BENCHES.
