Brief Description: Drilled remaining holes of the Vertical
DAVID WELDMAN HELPED ME POSITION AND THE REMAINING HOLES AND RIVET PLACEMENT ON THE FWD AND AFT SPAR OF THE VERTICAL. WE DETERMINED THE CENTERLINE OF THE AIRCRAFT AND THE EXACT POSITION OF THE STAB. WE MEASURED AND DRILLED THE 3 AN4 BOLT HOLES AT THE BASE OF THE VERTICAL STAB THA 812 BULKHEAD AND THE WD409 TAIL SPRING MOUNT.WE HAD TO TRIM THE LOWER PORTION OF THE VERTICAL STAB. AFTER FIXING THE F681 CONNECTOR IN PLACE, WE MISJUDGED ITS' POSITION AND WILL HAVE TO ORDER A NEW F681. I THEN MADE 2 8' SQUARES FOR THE PAINT BOOTH AND MOVED THE PEGBOARD AWAY FROM WHERE THE BOOTH WILL GO.
