Jaco Swanepoel's KR2S Web Site
Date:  12-29-2005
Number of Hours:  9.00
Brief Description:  Manifold & fuel line
I made some inlet manifold gaskets and fiitted the manifold. I drilled and tapped the manifold and fitted a line to the boost guage. I painted the fuel rail fittings and fitted the complete fuel rail. I drille a hole into the exhaust tail pipe and welded a fitting in place to fit the Lamda Sensor. I fit the Lambda Sensor and connected the wiring to the EFI.
