Ivans RV 10
RV10
Rudder and Brake Ped
8-23-2008
38-4 to 38-6
Pedals Assembly
38-4
Step 3 Match drilled the holes in the Beariong Block Mount Plates
Step 4 Final drilled remaining holes in mount plate and deburred.
Step 5 Bolted the bearing block mount plates to the FWD fuse longerons.
Step 6 Mounted blocks to pedals and then bolted to the block mounts.
38-5
Steps 1-3 Installed the center Rudder pedal block per instructions.
38-6
Step 1 Installed the brake hoses on the bulkhead elbow fittings. Connected other end to Pilot lower master cylinder ports.
RV10 Home
519
Aileron Actuation
Ailerons
Auto Pilot
Baggage Area
Baggage Door
Elevator
Empennage Attach
Fairings
Flaps
Horizontal Stabilize
Inventory
Tailcone
Tailcone Attach
Vertical Stabilizer
Wing Tips
Wiring
