Ivans RV 10
RV10
Empennage Attach
10-31-2007
Adjusting Pushrod for correct angle/ Rudder bearin
Secured elevators with duct tape in trailing position.
made template in Figure 1 out of cardboard.for 91.4 degrees.
Adjusted rod end bearings on Pushrod until angle of 91.4 degrees was dialed in on the F-635 Bellcrank Assembly and matched template.
Removed tape and tested elevators for free movement and for proper deflection.
Removed pushrod until needed later.
Put jam nuts on rudder end bearings and threaded rod ends onto rudder.to the distance stated in Figure 3, Detail A.
RV10 Home
519
Aileron Actuation
Ailerons
Auto Pilot
Baggage Area
Baggage Door
Elevator
Empennage Attach
Fairings
Flaps
Horizontal Stabilize
Inventory
Rudder and Brake Ped
Tailcone
Tailcone Attach
Vertical Stabilizer
Wing Tips
Wiring
