Ivans RV 10
RV10
Empennage Attach
10-18-2007
Horizontal Stabilizer Setup
Mounted Horizontal Stabilizer to Work bench and fastened down with screws through the HS1008 Front Spar Attachment Brackets. Then I set the Rear Spar on an 11/16 Spacer Block to hold HS in correct position for mounting elevators.
RV10 Home
519
Aileron Actuation
Ailerons
Auto Pilot
Baggage Area
Baggage Door
Elevator
Empennage Attach
Fairings
Flaps
Inventory
Rudder and Brake Ped
Tailcone
Tailcone Attach
Vertical Stabilizer
Wing Tips
Wiring
