Ivans RV 10
RV10
finish flap tube install
Finished installing flap control tubes and horn on right side and connecting to flap crank.
Mounted Flap motor and safety wired the extendable end to the flap crank bolt.
Mounted the FPS switch and actuator to the flap motor.
Mounted the FPS control box below the flap motor in tunnel.
Wired the flap motor and the FPS system at the flap motor.
RV10 Home
519
Aileron Actuation
Ailerons
Auto Pilot
Baggage Area
Baggage Door
Elevator
Empennage Attach
Fairings
Flaps
Horizontal Stabilize
Inventory
Rudder and Brake Ped
Tailcone
Tailcone Attach
Vertical Stabilizer
Wing Tips
Wiring
