Ivans RV 10
RV10
38-6, 38-8 to 8-10
brake tubing
38-6
Step 2 and 3 Made the soft brake lines and installed them as per plans. need to spiral wrap them when I get an order together.
38-7
Do later!
38-8 Strung rudder cables through tailcone and up through fuselage.
slid plastic sleeve into place and clamped it to the rudder cable angle .
Crossed rudder cables over each other as specified and ran up into fuse.
38-9
Step 1 Finished routing cables up through fuse and out the side of center section bulkhead.
38-10
Step 1 Made rudder cable links. WRONG!!! Order new ones. redid a few days later
Step 2 Made the rudder cable guides.
Step 3 match drilled the guides to 1048L & R fwd fuse ribs
Steps 4 & 5 finished guide prep and deburred.
Steps 6 & 7 Placed cables between guides and attached the guides as shown.
Step 8 Clamped the plastic sleeves over the cables and attached per plans.
Steps 9 & 10 Painted and installed the Links with hardware shown.
RV10 Home
519
Aileron Actuation
Ailerons
Auto Pilot
Baggage Area
Baggage Door
Elevator
Empennage Attach
Fairings
Flaps
Horizontal Stabilize
Inventory
Rudder and Brake Ped
Tailcone
Tailcone Attach
Vertical Stabilizer
Wing Tips
Wiring
