Brief Description: bent left and right tabs, 1st attempt
Bent one left and one right trim tab. Both were not useable. There is a significant misalignment between the top and bottom halves once bent. I need to sit and think this out. I have to go easy on my self as these are the first attempts at bending anything in aluminum sheet. This is a pretty complicated piece with tough, springy material. Hmmmm
Working on the trailing edge bend
Time for another attempt
0/2. Top and bottom have major mismatch after bending
