Finished glueing up the remaining aileron cove blocks on the left and right wing. Measured, re-measured and measured again the location for the pitot-static base and the two 3/16 bolt holes on the left wing front spar. Drilled and reamed the holes. Test fit the base and tubes. Looks good! Removed it all and applied first coat of CC to the front and rear face of the spar in the pitot rib bay.
