Brief Description: -5 ribs and spar butt plate install
Glued both -5 ribs, Bolted the spar butt plates and rib brackets in place. Match drilled using brackets to locate hole location for rib attachment. Installed remaining plate bolts and hardware. The hardware package was short of two AN970-3 washers for the rib brackets. I used 960's to assemble temporarily until the replacements arrive. Check the wings for squareness again out of curiousity. Still looking good. That's a relief because everything at the root is locked in with glue and bolts now! Also ordered some Torque Seal to mark all the nuts as they are installed.
