Unclamped the left wing and removed the pins. They came out pretty easy with pliers. Glued and clamped the right wing repeating the process. Prepared the all the -16 idler doublers for trimming the same as these. Lightly reamed and sanded the aileron and idler bellcrank bearing cages to accept the bearings with only light pressure.
