Brief Description: Spars marked with rib locations
Marked rib locations on all four spars. Moved all the lower ribs from storage closet to the garage to prep them for fitting and installation. Picked up some 3/16, 1/4, 5/16 and 3/8 smooth shanked bolts to use as assembly aids. The threads on the ends will be removed and the ends formed into a bullet shape. Set up Dremel with a small sanding drum for trim the spar slots on ribs. Trimmed 2 ribs for fit.
