Greg's Model 12 Build
Date:  2-7-2019
Brief Description:  Anchor nut location marking for trim tabs
Marked the Right elevator trim attach rib for anchor nut location. Discovered a slight blow in the rib with a straight edge. I'll plan to shim with washers as needed to prevent binding in the piano hinge.
Marked per plan spacing
1/16 gap on elevator
