Greg's Model 12 Build
Date:  7-29-2018
Brief Description:  Misc control brackets
Tacked and welded the mixture bracket in the left side of the rear cockpit between the former and vertical member. The former is .025 and very easy to burn away with too much heat. Clamped the right side brackets in place ready to tack and finish weld when I've had more sleep and less coffee.
Mixture bracket
Mixture bracket
mixture bracket on left side of fuse
Fuel valve and oil shutoff brackets
