Stripped the primer from the areas requiring the six trim cable fairleads welded. Also two areas under the front supports on each seat frame for crotch strap bushings. And along the bottom of the lower left longeron for step lugs. Used a 3M stripper wheel on the electric drill where it could reach and a Dremel with a wire brush attachment in the tight spots.
