Brief Description: Trimmed fuse fixture and removed brake lines
I cut off the mystery radio stack support at station 54. It was useful as a handle but would be a major hazard in a crash. I started picking at the ends of the brake lines glued into the trailing edge grooves on the Grove gear. They ended up being pretty easy to strip completely out of the grooves. I had originally thought they would not be useable without damaging the gear to get them out. This is a pleasant surprise and now I know they can be used as designed when the time comes.
