Masked off and painted the skybolt fasteners with primer and the painted white, so I could rivet on the clips. Used microfill around the oil door opening to get a nice flat edge, sanded smooth. Filled around some high spots at the front of the cowl and sanded smooth. Riveted on the side skybolt fasteners to the lower cowl. Cleaned up the inside of the cowls and sprayed/brushed on a coating of epoxy resin. Once this set on the top cowl, I gave another coat. Will prime the inside and paint, makes it easier to clean up oil spills if the inside is nice and smooth and painted (looks good to)
