I managed to stuff up the breather pipe, so down to the local metal supplier, picked up some more aluminium pipe, using a bender and lots of measuring (2 goes at pipe bending) I managed to have it bending from the top joined onto the enginme with some oil hose, joined to the firewall through 2 C clamps, does a little twist, has a loopy bend over the landing gear frame work,and curves around and lays along side the exhaust on the inside, cut and formed the small flute opening as well up the pipe. So hopefully any oil that does come down the tube will exit close enough to the exhaust to burn off and not dirty the belly of my plane.
