The final front inlet baffle was made and fitted, turned out very nice. I then mounted up the air intake tube, drilled the holes and temporarily bolted on, marked the cutout hole in the forward inlet baffle and cut this out. More trimming and measuring, rivet on the air intake angles to accept the filter.
