Cut the lengths of pipe that was supplied to correct length for the aileron push rods W-716 and W-818 for both wings. Drilled both end out and fitted screwed adaptors. Before I fitted the end I poured primer down into each pipe and washed it around until I felt it had a good coating inside. I will get all push rods powder coated to finish them off nicely.
