Riveted the front and rear spar together with the finished ribs. I had to drill out several rivets because I ended up putting smilies on some of the heads. The photo showing the lightening holes down the middle shows how good these kits are precision made. After finishing off riveting the rear spar assembly I drilled out the matching hole for the leading edge ribs and a couple off extra holes needed in the front spar.
