Running more wires from the stick grip up to the panel. The wires are for the power for grip, toggle, PTT radio switch and on/off switch. Finished the mouinting of the flap positioning sensor, this took quite a bit of time to find the correct length rod so the position sensor had enough travel up and down. I tried plenty of different methods until this one finally worked the best. Bolted in place and I used a touch of silastic on the bolts so hopefully they won't work free from vibration.
