Brief Description: Headset Jacks and Handbrake Support
Down to the nitty gritty with wiring. I thought OK, lets get the heatset jacks mounted, so after much deliberating of where to put them, I finally decided in between the two seats on the seat back support will do. I was going to put them near each arm rest but thought if I have panelling these would then be blocked, so in between the seats it is. I don't like cables on your lap so having these behind should eliminate this problem. (Just have to watch out if I'm loading anything in the rear and the jacks are not plugged in, otherwise could be disaster) Ordered the screened cable for the jacks this morning. I made the angle bracket for the park brake cable to be supported on the firewall angle, drilled the holes, alodined this small piece, painted with high temp silver paint, ready to rivet on permanently.
