Peters RV7A
Date:  1-7-2009
Number of Hours:  7.00
Brief Description:  Wingtip prep
Finished the glassing of the rope inside the right wingtip. I glassed in two cable tie down squares inside each wingtip so once the wires are connected to the lights and position/strobe lights I can neatly have the wires cable tied down so they are not flapping around.
I sprayed the left wingtip with 2 pak primer/filler and once dry sanded smooth checking for any holes or rough patches that nead more prep work. On a couple of areas where needed I used body filler to fill in small holes. Once the filler hardened it ws just a matter of wet & dry rubbing smooth, and give last thin coat of primer.
