Thought I might try and finish the wingtips. I did the same as I did on the empennage tips, drilled and countersunk on the aluminium tips ends, after alodining them, filled the angle bits in with expanding foam fill, trimmed these and then smoothed over a small coat of body filler. Once this is dry I sand the area nice and flat and then lay over the top of this a piece of fibreglass.
