Drilled out and dimpled the holes along the bottom of the fuselage where the wings will be screwed to the fuselage. Started to reassemble the panel ribs on the fuselage, dimpled the firewall where the three panel ribs attach. Riveted the three ribs onto the firewall, riveted the angle to the centre rib. I think I might cut out some lightening holes on the ribs so at least can run some wires through these if I need to, might do some research on the net to see what other builders have done first.
