Ran the right brake line, once again turned out nice just like the left side. I ran the clear/white brake line supplied as per Van's instructions, drilled the hole and mounting holes for the brake reservoir, fitted the clear/white lines to the brake cylinders on the pedals. I'm going to run braided hose line from the pedals to the parking brake valve and braided line from the parking brake valve down to the attachments which go to each wheel. So got the lengths organised I need and went down to my local 'Enzed Hose Doctor' for him to make up. Should look good. I primed and painted the brake cylinder and bolted it to the firewall with a dab of sikaflex high temp around the entry hole. Cut the brake tubing to length and fitted. I used a high temp silver colour to look like aluminium.
