I fitted the fuel vent line back in place, fit the rudder pedals for final time. I studied the plans and a few other builder's sites to work out where to place the matco park brake valve. First I had to bend up and make a mounting bracket to suit the valve which will go onto the firewall. Drilled the matching holes through the firewall, countersunk. Fitted the two brake fitings which go through the undercarriage mount. Ran the left brake line and connected to both ends, wasn't too bad and came out quite nice.
