Measured and cut the hinges for the seat floors for both sides, cut out the centres out of the hinges as told and smoothed off. Started the right side first and drilled the holes through the hinges first and then measured the lines on the right side skin floor and back drilled the seat floor through the hinge. Repeated for the left hand side, corrosion proofed (deoxidined and alodined) the seat floors, primed and then riveteted the hinges to the floors and riveted the floors to the airframe. Rivet all the platenuts on as well that has the tunel cover screw down onto. Another section finished.
