Decided to start preping parts, started with the F-684 gussets, aft canopy deck and armrests, corrosion proofed these, dimpled where needed and riveted the platenuts to the gussets. Next was to make the spacers and reinforcement angle for the fuel tank attach bracket. This took a while as I took my time and made sure it turned out perfect, dimpled and countersunk parts so they fitted nicely against the skin and angles. Nearly at the stage of dismantling this fuselage to prep and prime all the parts.
