Started the right elevator tip same as the left, filling, sanding, and glass work over the top. I put the aluminium strips inside the tip as per the left and slightly ground down the pop rivets I used to secure the tip to the elevator. This definately is a lot of work to get it to look nice. Not sure if I could build a plane out of fibreglass, too much sanding and filling.
