Cleaned up, filed and scotchbrite pad the two front reinforcement angles, tapered and bent to the correct angle, drilled the relief hole on the front spar. (Drilled the hole slightly on the wrong side and have contacted Vans's and they have said will be OK as this is not a high load area). Cleacoed and drilled all the correct holes to suit rivets, coming along nicely.
