Yay, finally finished all the wiring, programmed the skyview with the icons as I want them, tidied up all the wiring looms, fitted tunnel covers and as many covers as I require. Fitted the new modified fuel lines which go to my fuel 'red cube', bolted up the baffles which go around the bottom of the cylinders. I used stainless steel M4 all thread rod for this, much easier than the supplied rods of stainless steel. I decided to fit a LED warning light on my panel which will let me know if there is low oil pressure on start up. The avionics are not turned on untill after engine start and with the boot up time on the Dynan Skyview, I felt with the engine running for approx 30 secs to 1 min if there is a oil pressure problem I can shut the engine down.
