Connected and wired the alternator and the starter motor (disconnected the starter wire end so don't accidentally start the engine), used a few C-Clamps to keep the cables from touching anything they shouldn't. Connected the master battery cable to my panel switch, all lights up and works as it should. I'm going to have the fuse boards as essentials (ie EFIS, radio, transponder, autopilot, etc and lights, fuel pump etc on another board. The essentials are really the avionics so this board is going to be controlled by a avionics switch on the panel. I have all diodes and protection fuses in place to avoid any spikes. Fitted the Trio Propilot servo in my wing.
