Fitted the Dynan amps shunt. Made another copper bus out of some scrap from an old electrical distribution board, worked out great because it had a bend in it, just had to trim and drill a couple of holes, I heatshrunk some insulation over the bar centre and mounted in place. I like it because it is neat and makes for excellent contact. Also made the spike diodes up, soldered on some cable and covered in heatshrink insulation, the battery master diode allows current flow in one direction and the starter solenoid diode is mounted in an opposite direction, all works as it should as I tested contactor operation via a battery connected temporarily.
