Touched up a few rubbed back spots where the primer was thin, finished masking tap the fuselage, loaded onto a truck and off to the paint shop. WOW what a great spray job, very very happy with the finish. Cleaned off the empennage (bit dusty), fitted and bolted on the elevators. I might need to polish these a bit more now to match the glossy fuselage. Decided to repaint the vertical tail and rudder because I'm having the blue stripe down the fuselage and it has to match, so rubbing back the paint. Using paper to replicate a near exact curve for my design, I used a nylon edging/masking tape to mark out the design, need to rub this back with a grey scotchbrite pad to take the shine off the white, then cover the plane back up again with paper to keep off overspray.
