Hate glassing. I was not happy with the way the wheel pant worked out, didn't have enough meat at the rear where it tapers off and I could see this will eventually crack, so I bit the bullet and ripped it off, ordered a new one from Vans. Started on the left wheel pant, roughed up the surface cut and shaped the intersection fairing and allowed more meat at the rear, epoxy on. Trimed and marked all the holes for the front wheel pant as well, mounted up, just need to add some glass on the inside where it mounts. Started to prep and cut the front wheel pant, measured up the distance as per Van's plans.
