More wiring, I fitted the flap switch in the panel and wired this. I am using the smaller fuse board for all the avionics so ran more cables to this. It is taking a while to wire as I have said before, each wire run I have been printing off onto paper and heat shrinking the label onto the cable so I know which wire is what and where it comes from. It looks great but is time consuming but at least I know what is what and it isn't a big birds nest of cable. Also I decided to remove the flap positioning system, ended up being a headache, and I feel it will be more controllable if I operate the flaps manually.
